Hi,
I'm prompted with an error when running sudo wo maintenance and here's what the log say:
[32m2021-05-29 14:10:08,585 (INFO) wo : Initializing WordOps Database[0m
[32m2021-05-29 14:10:08,592 (INFO) wo : [94mupdating apt-cache, please wait...[0m
[32m2021-05-29 14:10:13,485 (INFO) wo : [94mupdating packages, please wait...[0m
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following NEW packages will be installed:
distro-info
The following packages will be upgraded:
apt apt-transport-https apt-utils cloud-init galera-4 grub-common
grub-efi-amd64 grub-efi-amd64-bin grub-efi-amd64-signed grub-pc-bin
grub2-common initramfs-tools initramfs-tools-bin initramfs-tools-core
libapache2-mod-php7.4 libapt-pkg-dev libapt-pkg6.0 libasound2
libasound2-data libldap-2.4-2 libldap-common libmariadb3 libnetplan0
libnss-systemd libpam-modules libpam-modules-bin libpam-runtime
libpam-systemd libpam0g libpci3 libprocps8 libseccomp2 libsystemd0 libudev1
linux-firmware mariadb-backup mariadb-client-10.5 mariadb-client-core-10.5
mariadb-common mariadb-server mariadb-server-10.5 mariadb-server-core-10.5
mysql-common netplan.io pciutils php7.3-bcmath php7.3-cli php7.3-common
php7.3-curl php7.3-fpm php7.3-gd php7.3-imap php7.3-intl php7.3-json
php7.3-mbstring php7.3-mysql php7.3-opcache php7.3-readline php7.3-recode
php7.3-soap php7.3-xml php7.3-zip php7.4 php7.4-bcmath php7.4-bz2 php7.4-cli
php7.4-common php7.4-curl php7.4-fpm php7.4-gd php7.4-imap php7.4-intl
php7.4-json php7.4-mbstring php7.4-mysql php7.4-opcache php7.4-readline
php7.4-soap php7.4-sybase php7.4-xml php7.4-xsl php7.4-zip procps
python3-distupgrade python3-software-properties python3-update-manager
qemu-guest-agent software-properties-common systemd systemd-sysv
ubuntu-advantage-tools ubuntu-release-upgrader-core udev update-manager-core
The following packages will be DOWNGRADED:
libssl1.1 openssl
94 upgraded, 1 newly installed, 2 downgraded, 0 to remove and 0 not upgraded.
E: Packages were downgraded and -y was used without --allow-downgrades.
[32m2021-05-29 14:10:14,877 (INFO) wo : [94m[91mOops Something went wrong!![0m
[31m2021-05-29 14:10:14,878 (ERROR) wo : [91mCheck the WordOps log for more details `tail /var/log/wo/wordops.log` and please try again...[0m
I can't seem to find any relevant information from the logs, what else can I do?
