Hello. I'm using wordops for a while and now I'm facing a problem which i did'n have before. On a VPS with Ubuntu 20.04 with 5.* kernel (AMD Epyc platform) incoming speed drops to nearly 50Mb/s after installing wo stack. https://www.speedtest.net/result/c/98100cca-398d-4c11-87d9-a97b46adb2c4
I have two other VPS with almost same config, but there are some different CPUs used there and this problem appears only on VPS with Epyc CPU.
I'm not good with VPS configuration and I don't know how to find out what causes the problem. I've tried to switch between kernels, and I've tried to purge WO from VPS, but problem still exists.
Hope someone can help with this problem. Sorry for my English, I'm not a native speaker.
