Hi folks,
I did a wo update which updated to latest version of WordOps. I am not sure what version it was on before, but likely hadn't been updated for at least 6 months. The update when fine.
I then did a wo stack upgrade ... and it seemed to be going fine, but when I returned to the console (after leaving it for a few hours), it was hung on Stop : netdata [OK]. I assume it was hung, as I've never seen it take anything like 2+ hours for the stack upgrade before.
I hit CTRL-C a few times to break out of the script. This was the output:
natnut@nhnut:~$ wo stack upgrade
Nginx Stable is not already installed
Your sites may be down for few seconds if you are upgrading Nginx, PHP-FPM, MariaDB or Redis
Do you want to continue:[y/N]y
Updating APT cache [OK]
Configuring php7.3-fpmes [..]
Restarting php7.3-fpm [OK]
Configuring php7.4-fpm
Restarting php7.4-fpm [OK]
Tuning MySQL configuration [OK]
Restarting mariadb [OK]
Restarting fail2ban [OK]
Configuring Fail2Ban
Configuring APT Packages [OK]
Downloading WP-CLI [Done]
Downloading Netdata [Done]
Downloading WordOps Dashboard [Done]
Downloading PHPMyAdmin [Done]
Downloading Adminer [Done]
Downloading Adminer theme [Done]
Downloading Composer [Done]
Downloading MySQLTuner [Done]
Downloading ngxblocker [Done]
Stop : netdata [OK]
^CTraceback (most recent call last):
File "/opt/wo/lib/python3.8/site-packages/wo/core/shellexec.py", line 24, in cmd_exec
(cmd_stdout_bytes, cmd_stderr_bytes) = proc.communicate()
File "/usr/lib/python3.8/subprocess.py", line 1028, in communicate
stdout, stderr = self._communicate(input, endtime, timeout)
File "/usr/lib/python3.8/subprocess.py", line 1868, in _communicate
ready = selector.select(timeout)
File "/usr/lib/python3.8/selectors.py", line 415, in select
fd_event_list = self._selector.poll(timeout)
File "/opt/wo/lib/python3.8/site-packages/cement/core/foundation.py", line 123, in cement_signal_handler
raise exc.CaughtSignal(signum, frame)
cement.core.exc.CaughtSignal: Caught signal 2
During handling of the above exception, another exception occurred:
File "/usr/local/bin/wo", line 8, in <module>
sys.exit(main())
File "/opt/wo/lib/python3.8/site-packages/wo/cli/main.py", line 102, in main
app.run()
File "/opt/wo/lib/python3.8/site-packages/cement/core/foundation.py", line 882, in run
return_val = self.controller._dispatch()
File "/opt/wo/lib/python3.8/site-packages/cement/core/controller.py", line 471, in _dispatch
return func()
return func()
File "/opt/wo/lib/python3.8/site-packages/cement/core/controller.py", line 477, in _dispatch
return func()
File "/opt/wo/lib/python3.8/site-packages/wo/cli/plugins/stack_upgrade.py", line 389, in default
WOShellExec.cmd_exec(
File "/opt/wo/lib/python3.8/site-packages/wo/core/shellexec.py", line 38, in cmd_exec
raise CommandExecutionError
wo.core.shellexec.CommandExecutionError
I tried running wo stack upgrade again, and it finished quickly (a minute or so), with all OK. As follows:
[sudo] password for natnut:
WordOps dashboard is not installed
Stop : netdata [OK]
Upgrading Netdata [OK]
Upgrading Composer [OK]
Upgrading phpMyAdmin [OK]
Successfully updated packages
But the site has been down ever since.
I rebooted the server, and it's still down.
Where to from here?
