I run Ubuntu 22.02 LTS and I'm trying to install GeoIP2 module using this command:
sudo apt-get install libnginx-mod-http-geoip2 but it gives error
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libnginx-mod-http-geoip2 : Depends: nginx-common (= 1.18.0-6ubuntu14.8) but 1.28.2-2ppa~stable~bpo22.04.1 is to be installed
Recommends: nginx
E: Unable to correct problems, you have held broken packages.
How to fix this?
