root@localhost:# systemctl status nginx.service
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled)
Active: failed (Result: exit-code) since Tue 2019-12-24 18:30:37 UTC; 1min 9s ago
Process: 31640 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=1/FAILURE)
Dec 24 18:30:37 localhost nginx[31640]: nginx: [emerg] open() "/etc/nginx/common/locations-wo.conf" failed (2: No such file or directory) in /etc/nginx/sites-enabled/abrilpraangola.com:21
Dec 24 18:30:37 localhost nginx[31640]: nginx: configuration file /etc/nginx/nginx.conf test failed
Dec 24 18:30:37 localhost systemd[1]: nginx.service: control process exited, code=exited status=1
Dec 24 18:30:37 localhost systemd[1]: Failed to start A high performance web server and a reverse proxy server.
Dec 24 18:30:37 localhost systemd[1]: Unit nginx.service entered failed state.
