KevinKyburz Hey, where can i find the https conf file? I created a new multisite sub page with -le and the backend has sometime https but in the site settings from the dashboard the url is simple http and not https. A new ssl install with force doesnt change anyting. Thank you.
portofacil All configuration files for a given domain are in /var/www/domain.com/conf/nginx. However, I think you have to configure your WP, not Nginx, to achieve HTTPS wherever you need. Sorry, but I really could not understand your question.
KevinKyburz Thank you. I used the better search replace plugin. Its strange, other installations working good with https, just this one had problems.
