Hello everybody, How are you?
I need your help, suddenly all my sites went offline, with the message "database error"
Then I went to look at the terminal and tried the command to restart, and 'msql is not installed' appeared, then I asked myself, but how was everything normal until yesterday?
then I went to install mysql again and it gives an error, can someone help me? he asks to go to the log, and I went to the log and asks to execute the command "You might want to run 'apt-get -f install' to correct these:" I did the command and it still didn't work, help me.
prints
1.https://prnt.sc/sg6j76
2.https://prnt.sc/sg6luv
3.https://prnt.sc/sg6mh5
log
Reading package lists...
Building dependency tree...
Reading state information...
The following packages have unmet dependencies:
kde-telepathy-minimal : Depends: kde-config-telepathy-accounts (>= 15.04.0) but it is not going to be installed
mariadb-client : Depends: mariadb-client-10.3 (>= 1:10.3.23+mariaxenial) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
2020-05-13 19:25:38,603 (INFO) wo : [94m[91mOops Something went wrong!![0m
2020-05-13 19:25:38,603 (ERROR) wo : [91mCheck the WordOps log for more details tail /var/log/wo/wordops.log and please try again...[0m
