Hello everyone, everything good?
I have a big problem.
To give you an idea 50 of my sites are down.
After doing the following command wo stack upgrade
See the result:
Netdata is not installed
WordOps dashboard is not installed
phpMyAdmin isn't installed
Adminer isn't installed
Composer isn't installed
Your sites may be down for few seconds if you are upgrading Nginx, PHP-FPM, MariaDB or Redis
Do you want to continue:[y/N]y
Whoops, something went wrong... [..]
Check the WordOps log for more detailstail /var/log/wo/wordops.log` and please try again...
root@localhost:~# tail /var/lo
local/ lock/ log/
root@localhost:~# tail /var/log/wo/wordops.log
2020-07-13 18:50:59,025 (INFO) wo : Composer isn't installed
2020-07-13 18:50:59,025 (DEBUG) wo.core.logging : Setting packages variable for MySQLTuner
2020-07-13 18:50:59,026 (WARNING) wo : Your sites may be down for few seconds if you are upgrading Nginx, PHP-FPM, MariaDB or Redis
2020-07-13 18:51:06,299 (INFO) wo : Updating APT cache
W: GPG error: http://packages.dotdeb.org jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E9C74FEEA2098A6E
W: Failed to fetch https://packages.sury.org/php/dists/jessie/main/binary-amd64/Packages HttpError404
E: Some index files failed to download. They have been ignored, or old ones used instead.
2020-07-13 18:51:18,635 (INFO) wo : Whoops, something went wrong...
2020-07-13 18:51:18,636 (ERROR) wo : Check the WordOps log for more details tail /var/log/wo/wordops.log and please try again...`
Could someone help me with this problem.
I don't know anything about infrastructure.
