stantyan Hi, does anyone know if I should manually run some commands once every 90 days in order to renew letsencrypt or WordOps is doing everything for me? Can't find anything related to this in documentation. Thanks!
JuanMaia You should have this as you type: $ crontab -l / Etc / letsencrypt "/ etc / letsencrypt / config" /etc/letsencrypt "/ etc / letsencrypt" /config-home "/ dev / null
stantyan Thank you so much for your replies! I checked the crontab and everything is perfect. So glad I'm moving to WordOps from EasyEngine now.
