Hello!
After upgrading wordops to 3.12.4 I try to wo stack upgrade
and getting error:
root@ubuntu-8gb-hel1-1 ~ # wo stack upgrade
Your sites may be down for few seconds if you are upgrading Nginx, PHP-FPM, MariaDB or Redis
Do you want to continue:[y/N]y
Updating APT cache [OK]
Adding repository for NGINX, please wait...
Applying Nginx configuration templates
Testing Nginx configuration [OK]
Restarting Nginx [OK]
Oops Something went wrong!!
Check the WordOps log for more details `tail /var/log/wo/wordops.log` and please try again...
Checking wo stack status
I see this:
root@ubuntu-8gb-hel1-1 ~ # wo stack status
PHP7.2-FPM is not installed
PHP7.3-FPM is not installed
PHP7.4-FPM is not installed
fail2ban is not installed
UFW Firewall is disabled
nginx : Running
mysql : Running
Just install theese stacks and all going to be ok.
And Nginx not upgraded tot 1.18. Now it's 1.16.1
But is that okay?
