Update
Here is the log, its seems to me that its not installing mysql database.
Please help. Thanks
[32m2021-08-27 02:39:19,791 (INFO) wo : Initializing WordOps Database[0m
[32m2021-08-27 02:39:19,800 (INFO) wo : [94mSynchronizing wo database, please wait...[0m
[32m2021-08-27 02:39:33,537 (INFO) wo : Initializing WordOps Database[0m
[36m2021-08-27 02:39:33,539 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for Nginx[0m
[36m2021-08-27 02:39:33,539 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for PHP 7.3[0m
[36m2021-08-27 02:39:34,108 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for MySQL[0m
[36m2021-08-27 02:39:34,109 (DEBUG) wo.core.logging : [95mRunning command: mysqladmin ping[0m
[36m2021-08-27 02:39:34,113 (DEBUG) wo.core.logging : [95mCommand Output: ,
Command Error: /bin/sh: 1: mysqladmin: not found
[0m
[36m2021-08-27 02:39:34,114 (DEBUG) wo.core.logging : [95mSetting packages variable for WP-CLI[0m
[36m2021-08-27 02:39:34,114 (DEBUG) wo.core.logging : [95mWP-CLI is already installed[0m
[32m2021-08-27 02:39:34,114 (INFO) wo : [94mWP-CLI is already installed[0m
[36m2021-08-27 02:39:34,114 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for Fail2ban[0m
[36m2021-08-27 02:39:34,691 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for Sendmail[0m
[36m2021-08-27 02:39:36,473 (DEBUG) wo.core.logging : [95mAnother mta (Postfix) is already installed[0m
[32m2021-08-27 02:39:36,474 (INFO) wo : [94mAnother mta (Postfix) is already installed[0m
[36m2021-08-27 02:39:36,474 (DEBUG) wo.core.logging : [95mSetting packages variable for phpMyAdmin [0m
[36m2021-08-27 02:39:36,474 (DEBUG) wo.core.logging : [95mSetting packages variable for phpRedisAdmin[0m
[36m2021-08-27 02:39:36,474 (DEBUG) wo.core.logging : [95mSetting packages variable for Composer [0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for Adminer [0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for MySQLTuner [0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for Netdata[0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for WO-Dashboard[0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for eXtplorer[0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for cheat.sh[0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mSetting packages variable for nanorc[0m
[36m2021-08-27 02:39:36,475 (DEBUG) wo.core.logging : [95mRunning command: mysqladmin ping[0m
[36m2021-08-27 02:39:36,480 (DEBUG) wo.core.logging : [95mCommand Output: ,
[0m
[36m2021-08-27 02:39:38,227 (DEBUG) wo.core.logging : [95mSetting packages variable for utils[0m
[36m2021-08-27 02:39:38,229 (DEBUG) wo.core.logging : [95mFinding string container=lxc to file /proc/1/environ[0m
[36m2021-08-27 02:39:38,229 (DEBUG) wo.core.logging : [95mFinding string wsl to file /proc/1/environ[0m
[36m2021-08-27 02:39:38,230 (DEBUG) wo.core.logging : [95mWritting the configuration to file /opt/wo-kernel.sh[0m
[36m2021-08-27 02:39:38,232 (DEBUG) wo.core.logging : [95mChanging permission of /opt/wo-kernel.sh, Perm:448[0m
[36m2021-08-27 02:39:38,232 (DEBUG) wo.core.logging : [95mWritting the configuration to file /lib/systemd/system/wo-kernel.service[0m
[36m2021-08-27 02:39:38,232 (DEBUG) wo.core.logging : [95mRunning command: systemctl enable wo-kernel.service[0m
[36m2021-08-27 02:39:38,445 (DEBUG) wo.core.logging : [95mCommand Output: ,
Command Error: Created symlink /etc/systemd/system/wo-kernel.service → /lib/systemd/system/wo-kernel.service.
Created symlink /etc/systemd/system/multi-user.target.wants/wo-kernel.service → /lib/systemd/system/wo-kernel.service.
[0m
[32m2021-08-27 02:39:38,446 (INFO) wo : [94mStart : wo-kernel [0m
[32m2021-08-27 02:39:38,984 (INFO) wo : [94m[[0m[92mOK[0m[94m][0m
[36m2021-08-27 02:39:38,985 (DEBUG) wo.core.logging : [95mFinding string 500000 to file /etc/security/limits.conf[0m
[36m2021-08-27 02:39:38,986 (DEBUG) wo.core.logging : [95mWritting the configuration to file /etc/update-motd.d/98-wo-update[0m
[36m2021-08-27 02:39:38,987 (DEBUG) wo.core.logging : [95mChanging permission of /etc/update-motd.d/98-wo-update, Perm:493[0m
[36m2021-08-27 02:39:38,987 (DEBUG) wo.core.logging : [95mCalling pre_pref[0m
[32m2021-08-27 02:39:38,987 (INFO) wo : [94mAdding repository for MySQL, please wait...[0m
[36m2021-08-27 02:39:38,988 (DEBUG) wo.core.logging : [95mRunning command: apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0xcbcb082a1bb943db[0m
[36m2021-08-27 02:39:40,428 (DEBUG) wo.core.logging : [95mCommand Output: Executing: /tmp/apt-key-gpghome.ZrTKLN66L2/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0xcbcb082a1bb943db
Command Error: Warning: apt-key output should not be parsed (stdout is not a terminal)
gpg: key CBCB082A1BB943DB: public key "MariaDB Package Signing Key package-signing-key@mariadb.org" imported
gpg: Total number processed: 1
gpg: imported: 1
[0m
[36m2021-08-27 02:39:40,429 (DEBUG) wo.core.logging : [95mRunning command: apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0xF1656F24C74CD1D8[0m
[36m2021-08-27 02:39:41,160 (DEBUG) wo.core.logging : [95mCommand Output: Executing: /tmp/apt-key-gpghome.EvNVwQEbg5/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0xF1656F24C74CD1D8
gpg: key F1656F24C74CD1D8: "MariaDB Signing Key signing-key@mariadb.org" not changed
gpg: unchanged: 1
[0m
[36m2021-08-27 02:39:41,162 (DEBUG) wo.core.logging : [95mWritting configuration into MySQL file[0m
[36m2021-08-27 02:39:41,163 (DEBUG) wo.core.logging : [95mSetting my.cnf permission[0m
[36m2021-08-27 02:39:41,163 (DEBUG) wo.core.logging : [95mChanging permission of /etc/mysql/conf.d/my.cnf.tmp, Perm:384[0m
[32m2021-08-27 02:39:41,164 (INFO) wo : [94mAdding repository for NGINX, please wait...[0m
[36m2021-08-27 02:39:41,164 (DEBUG) wo.core.logging : [95mppa_author = wordops[0m
[36m2021-08-27 02:39:41,165 (DEBUG) wo.core.logging : [95mppa_package = nginx-wo[0m
[36m2021-08-27 02:39:41,165 (DEBUG) wo.core.logging : [95mRunning command: LC_ALL=C.UTF-8 add-apt-repository -y 'ppa:wordops/nginx-wo'[0m
[36m2021-08-27 02:39:48,946 (DEBUG) wo.core.logging : [95mCommand Output: Hit:1 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:2 http://us-sanjose-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:3 http://us-sanjose-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:4 http://us-sanjose-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:5 http://nginx.org/packages/mainline/ubuntu focal InRelease
Hit:6 http://ppa.launchpad.net/ondrej/nginx-mainline/ubuntu focal InRelease
Hit:7 http://mirrors.up.pt/pub/mariadb/repo/10.4/ubuntu focal InRelease
Hit:8 http://ppa.launchpad.net/ondrej/nginx/ubuntu focal InRelease
Get:9 http://mariadb.mirrors.ovh.net/MariaDB/repo/10.5/ubuntu focal InRelease [7758 B]
Hit:10 http://ppa.launchpad.net/ondrej/php/ubuntu focal InRelease
Get:11 http://ppa.launchpad.net/wordops/nginx-wo/ubuntu focal InRelease [18.0 kB]
Get:12 http://mariadb.mirrors.ovh.net/MariaDB/repo/10.5/ubuntu focal/main amd64 Packages [17.4 kB]
Get:13 http://mariadb.mirrors.ovh.net/MariaDB/repo/10.5/ubuntu focal/main ppc64el Packages [16.6 kB]
Get:14 http://ppa.launchpad.net/wordops/nginx-wo/ubuntu focal/main arm64 Packages [2268 B]
Get:15 http://ppa.launchpad.net/wordops/nginx-wo/ubuntu focal/main Translation-en [2268 B]
Fetched 64.3 kB in 2s (30.4 kB/s)
Reading package lists...
Command Error: W: Target Sources (main/source/Sources) is configured multiple times in /etc/apt/sources.list:53 and /etc/apt/sources.list:54
[0m
[36m2021-08-27 02:39:48,947 (DEBUG) wo.core.logging : [95mAdded PPA ppa:wordops/nginx-wo[0m
[36m2021-08-27 02:39:48,947 (DEBUG) wo.core.logging : [95mAdding ppa for Nginx[0m
[36m2021-08-27 02:39:48,947 (DEBUG) wo.core.logging : [95mAdding ppa for PHP[0m
[32m2021-08-27 02:39:48,948 (INFO) wo : [94mAdding repository for PHP, please wait...[0m
[36m2021-08-27 02:39:48,948 (DEBUG) wo.core.logging : [95mppa_author = ondrej[0m
[36m2021-08-27 02:39:48,948 (DEBUG) wo.core.logging : [95mppa_package = php[0m
[36m2021-08-27 02:39:48,948 (DEBUG) wo.core.logging : [95mppa already added[0m
[32m2021-08-27 02:39:48,948 (INFO) wo : [94mUpdating apt-cache [0m
[32m2021-08-27 02:39:51,182 (INFO) wo : [92mUpdating apt-cache [0m
[32m2021-08-27 02:39:51,182 (INFO) wo : [94mInstalling APT packages [0m
Building dependency tree...
Reading state information...
Package nginx-custom is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
nginx-common
E: Package 'nginx-custom' has no installation candidate
E: Unable to locate package nginx-wo
[32m2021-08-27 02:39:51,552 (INFO) wo : [94m[91mOops Something went wrong!![0m
[31m2021-08-27 02:39:51,553 (ERROR) wo : [91mCheck the WordOps log for more details tail /var/log/wo/wordops.log and please try again...[0m
