• Questions
  • Random Error establishing a database connection, but no errors in log.
Thank you tyrro your support. I do not use a my.cnf file. This is my 50-server.cnf
# MariaDB database server configuration file.
# Optimized by WordOps 3.13.2
# You can copy this file to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port		= 3306
socket		= /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice		= 0
[mysqld]
# * Basic Settings
user		= mysql
pid-file	= /var/run/mysqld/mysqld.pid
port		= 3306
basedir		= /usr
datadir		= /var/lib/mysql
tmpdir		= /tmp
lc_messages_dir	= /usr/share/mysql
lc_messages	= en_US
skip-external-locking
skip-name-resolve
log-error = /var/log/mysql/error.log
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address		= ::ffff:127.0.0.1
# * Fine Tuning
max_connections		= 80
connect_timeout		= 5
wait_timeout		= 60
max_allowed_packet	= 64M
thread_cache_size	= 80
sort_buffer_size	= 4M
bulk_insert_buffer_size	= 16M
tmp_table_size		= 32M
max_heap_table_size	= 32M
table_definition_cache = 700
# * MyISAM
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched. On error, make copy and try a repair.
myisam_recover_options = BACKUP
key_buffer_size		= 128M
open-files-limit	= 500000
table_open_cache	= 16000
myisam_sort_buffer_size	= 512M
concurrent_insert	= 2
read_buffer_size	= 2M
read_rnd_buffer_size	= 1M
# * Query Cache Configuration
# Cache only tiny result sets, so we can fit more in the query cache.
query_cache_limit		= 128K
query_cache_size		= 0
# for more write intensive setups, set to DEMAND or OFF
query_cache_type		= 0
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file        = /var/log/mysql/mysql.log
#general_log             = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# we do want to know about network errors and such
log_warnings		= 2
# Enable the slow query log to see queries with especially long duration
slow_query_log = 1
slow_query_log_file	= /var/log/mysql/mariadb-slow.log
long_query_time = 10
#log_slow_rate_limit	= 1000
log_slow_verbosity	= query_plan
#log-queries-not-using-indexes
#log_slow_admin_statements
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#       other settings you may need to change.
#server-id		= 1
#report_host		= master1
#auto_increment_increment = 2
#auto_increment_offset	= 1
#log_bin			= /var/log/mysql/mariadb-bin
#log_bin_index		= /var/log/mysql/mariadb-bin.index
# not fab for performance, but safer
#sync_binlog		= 1
#expire_logs_days	= 10
#max_binlog_size         = 100M
transaction_isolation = READ-COMMITTED
binlog_format = ROW
# slaves
#relay_log		= /var/log/mysql/relay-bin
#relay_log_index	= /var/log/mysql/relay-bin.index
#relay_log_info_file	= /var/log/mysql/relay-bin.info
#log_slave_updates
#read_only
# If applications support it, this stricter sql_mode prevents some
# mistakes like inserting invalid dates etc.
#sql_mode		= NO_ENGINE_SUBSTITUTION,TRADITIONAL
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
default_storage_engine	= InnoDB
# you can't just change log file size, requires special procedure
innodb_log_file_size	= 74M
#innodb_buffer_pool_size	= 595M
innodb_buffer_pool_size	= 200M
#innodb_log_buffer_size	= 148M
innodb_log_buffer_size	= 100M
innodb_file_per_table	= 1
innodb_open_files	= 500000
innodb_io_capacity	= 500000
innodb_flush_method	= O_DIRECT
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
# * Galera-related settings
[galera]
# Mandatory settings
#wsrep_on=ON
#wsrep_provider=
#wsrep_cluster_address=
#binlog_format=row
#default_storage_engine=InnoDB
#innodb_autoinc_lock_mode=2
# Allow server to accept connections on all interfaces.
#bind-address=0.0.0.0
# Optional setting
#wsrep_slave_threads=1
#innodb_flush_log_at_trx_commit=0
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash	# faster start of mysql but no tab completion
[isamchk]
key_buffer		= 16M
# * IMPORTANT: Additional settings that can override those from this file!
#   The files must end with '.cnf', otherwise they'll be ignored.
Are you using MyISAM tables?
Can you run and provide output of the mysqltuner?
The first thing I would do is If your max connection usage never exceeds 50% from 80, then reduce it to say 60. The rest depends on the output of mysqltuner, I need to see your data usage to give you any optimization tips.
But this is not related to your error: "Cannot establish a database connection" . There must be something in the logs to have some hint on what went wrong.
    tyrro
    Again thank you for your support.
    Could you please help me to change the "Maximum possible memory usage: 6.2G" to below 2GB. I have only 2GB RAM.
    No, all WordPress sites use InnoDB tables.
    Today error log file is empty. Still, I didn't receive any corn failed email. I have little suspect about monit (it may restart MySQL when it uses high memory).
    This is my mysqltuner output.
    MySQLTuner 1.8.1 - Major Hayden major@mhtx.net
    Bug reports, feature requests, and downloads at http://mysqltuner.pl/
    Run with '--help' for additional options and output filtering
    [--] Skipped version check for MySQLTuner script
    [OK] Logged in using credentials passed on the command line
    [OK] Currently running supported MySQL version 10.5.12-MariaDB-1:10.5.12+mariafocal-log
    [OK] Operating on 64-bit architecture
    -------- Log file Recommendations ------------------------------------------------------------------
    [OK] Log file /var/log/mysql/error.log exists
    [--] Log file: /var/log/mysql/error.log(0B)
    [--] Log file /var/log/mysql/error.log is empty. Assuming log-rotation. Use --server-log={file} for explicit file
    -------- Storage Engine Statistics -----------------------------------------------------------------
    [--] Status: +Aria +CSV +InnoDB +MEMORY +MRG_MyISAM +MyISAM +PERFORMANCE_SCHEMA +SEQUENCE
    [--] Data in InnoDB tables: 138.8M (Tables: 407)
    [--] Data in MyISAM tables: 4.6M (Tables: 2)
    [OK] Total fragmented tables: 0
    -------- Analysis Performance Metrics --------------------------------------------------------------
    [--] innodb_stats_on_metadata: OFF
    [OK] No stat updates during querying INFORMATION_SCHEMA.
    -------- Security Recommendations ------------------------------------------------------------------
    [OK] There are no anonymous accounts for any database users
    [OK] All database users have passwords assigned
    [!!] There is no basic password file list!
    -------- CVE Security Recommendations --------------------------------------------------------------
    [--] Skipped due to --cvefile option undefined
    -------- Performance Metrics -----------------------------------------------------------------------
    [--] Up for: 23h 32m 3s (492K q [5.814 qps], 6K conn, TX: 2G, RX: 111M)
    [--] Reads / Writes: 80% / 20%
    [--] Binary logging is disabled
    [--] Physical Memory : 1.9G
    [--] Max MySQL memory : 6.2G
    [--] Other process memory: 0B
    [--] Total buffers: 644.0M global + 71.5M per thread (80 max threads)
    [--] P_S Max memory usage: 0B
    [--] Galera GCache Max memory usage: 0B
    [!!] Maximum reached memory usage: 2.4G (126.13% of installed RAM)
    [!!] Maximum possible memory usage: 6.2G (320.71% of installed RAM)
    [!!] Overall possible memory usage with other process exceeded memory
    [OK] Slow queries: 0% (0/492K)
    [OK] Highest usage of available connections: 32% (26/80)
    [OK] Aborted connections: 0.65% (40/6144)
    [OK] Query cache is disabled by default due to mutex contention on multiprocessor machines.
    [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 23K sorts)
    [OK] No joins without indexes
    [OK] Temporary tables created on disk: 4% (11K on disk / 277K total)
    [OK] Thread cache hit rate: 99% (31 created / 6K connections)
    [OK] Table cache hit rate: 99% (213K hits / 213K requests)
    [OK] table_definition_cache(700) is upper than number of tables(602)
    [OK] Open file limit used: 0% (62/500K)
    [OK] Table locks acquired immediately: 100% (1K immediate / 1K locks)
    -------- Performance schema ------------------------------------------------------------------------
    [--] Performance schema is disabled.
    [--] Memory used by P_S: 0B
    [--] Sys schema isn't installed.
    -------- ThreadPool Metrics ------------------------------------------------------------------------
    [--] ThreadPool stat is enabled.
    [--] Thread Pool Size: 1 thread(s).
    [--] Using default value is good enough for your version (10.5.12-MariaDB-1:10.5.12+mariafocal-log)
    -------- MyISAM Metrics ----------------------------------------------------------------------------
    [!!] Key buffer used: 18.2% (24M used / 134M cache)
    [OK] Key buffer size / total MyISAM indexes: 128.0M/1.3M
    -------- InnoDB Metrics ----------------------------------------------------------------------------
    [--] InnoDB is enabled.
    [--] InnoDB Thread Concurrency: 0
    [OK] InnoDB File per table is activated
    [OK] InnoDB buffer pool / data size: 256.0M/138.8M
    [OK] Ratio InnoDB log file size / InnoDB Buffer pool size: 74.0M * 1/256.0M should be equal to 25%
    [--] Number of InnoDB Buffer Pool Chunk : 2 for 1 Buffer Pool Instance(s)
    [OK] Innodb_buffer_pool_size aligned with Innodb_buffer_pool_chunk_size & Innodb_buffer_pool_instances
    [OK] InnoDB Read buffer efficiency: 99.94% (11404902 hits/ 11411464 total)
    [!!] InnoDB Write Log efficiency: 711.71% (30383 hits/ 4269 total)
    [OK] InnoDB log waits: 0.00% (0 waits / 34652 writes)
    -------- Aria Metrics ------------------------------------------------------------------------------
    [--] Aria Storage Engine is enabled.
    [OK] Aria pagecache size / total Aria indexes: 128.0M/336.0K
    [!!] Aria pagecache hit rate: 83.1% (64K cached / 10K reads)
    -------- TokuDB Metrics ----------------------------------------------------------------------------
    [--] TokuDB is disabled.
    -------- XtraDB Metrics ----------------------------------------------------------------------------
    [--] XtraDB is disabled.
    -------- Galera Metrics ----------------------------------------------------------------------------
    [--] Galera is disabled.
    -------- Replication Metrics -----------------------------------------------------------------------
    [--] Galera Synchronous replication: NO
    [--] No replication slave(s) for this server.
    [--] Binlog format: ROW
    [--] XA support enabled: ON
    [--] Semi synchronous replication Master: OFF
    [--] Semi synchronous replication Slave: OFF
    [--] This is a standalone server
    -------- Recommendations ---------------------------------------------------------------------------
    General recommendations:
    MySQL was started within the last 24 hours - recommendations may be inaccurate
    Reduce your overall MySQL memory footprint for system stability
    Dedicate this server to your database for highest performance.
    Performance schema should be activated for better diagnostics
    Consider installing Sys schema from https://github.com/mysql/mysql-sys for MySQL
    Consider installing Sys schema from https://github.com/FromDual/mariadb-sys for MariaDB
    Variables to adjust:
    *** MySQL's maximum memory usage is dangerously high ***
    *** Add RAM before increasing MySQL buffer variables ***
    performance_schema = ON enable PFS
    jounin It is useless. Because this server never each at least 80% RAM usage. Always it is below 1.2GB.
    He doesn't need to upgrade at this time, his amount of data is small. He just need to adjust MySQL my.cnf config file to use less resources. I'll try to send you my recommendations tomorrow.
      tyrro I did few changes. Right now it mysqltuner not showing high RAM usage warning.
      I made the following changes in my 50-server.cnf. Is this optimization ok for 10 WordPress sites (FastCGI enabled). After changed max_allowed_packet it drastically change the max memory usage. Is it safe?
      **Changed following values in wordops default 50-server.cnf**
      max_allowed_packet  =	 32M
      sort_buffer_size	   = 256K
      read_rnd_buffer_size   = 256K
      read_buffer_size	    = 256K
      key_buffer_size	= 16M
      open-files-limit	= 1024
      query_cache_size	= 50M
      query_cache_limit    = 256K
      innodb_buffer_pool_size = 450M
      innodb_log_file_size	= 112M
      **Newly added options**
      skip-name-resolve
      table_definition_cache = -1
      innodb_lru_scan_depth = 1024
      query_cache_min_res_unit = 2k
      innodb_log_files_in_group	= 2
      You don't need to change your innodb_buffer_pool_size = 450M, 450 is a lot, you only use 139M of data according to sqltuner report. So reduce it back to 200M.
      Reduce key_buffer_size to 64M.
      Reduce myisam_sort_buffer_size from 512M to 128M.
      Reduce your max_connections to 60.
      Let's try with these and reload your mysql. Then run mysqltuner again to see the resulting data usage.
      Most likely you're getting Error establishing a database connection because your mysql instance went down when it used 129.87% of installed RAM according to your data. Server just went out of memory.
        tyrro Again thank your support.
        As per your recommendation, I change that value. However, If I use max_connections to 60 again mysqltunershows Maximum possible memory usage warning. If I set it to 30 then mysqltuner shows it is ok.
        Are there any negative impact when change max_allowed_packet to 32M
        Do not reduce max_connections if you have seen max usage of around 40, let's just keep it at 60 and lower other settings. I don't have time now but I will take a look tomorrow. Reduce max_allowed_packet to 16M.
          tyrro Thank you. OK, once you get free please reply to this thread. No hurry. 😀
          For testing purposes, I have changed max_connectionsto 60, and max_allowed_packetto 16M, then mysqltuner shows [!!] Maximum possible memory usage: 1.7G (86.39% of installed RAM).
          So I change max_connectionsto 50, now it is [OK] Maximum possible memory usage: 1.5G (77.69% of installed RAM)
          But now it shows [!!] InnoDB Write Log efficiency: 188.45% (1321 hits/ 701 total)
          If you never gonna use replication you don't need to keep binary logs, here's a good article how to disable them.
          https://geekflare.com/disable-binary-log-mariadb/
          For InnoDB proper log size read these articles: https://dzone.com/articles/how-to-choose-the-mysql-innodb-log-file-size and https://scalegrid.io/blog/calculating-innodb-buffer-pool-size-for-your-mysql-server/
          further reduce key_buffer_size to 32M
          further reduce myisam_sort_buffer_size to 32M
          if you don't trying to find slow queries, disable slow_query_log = 0, instead of 1.
          reduce both
          innodb_io_capacity = 500000 to say 400.
          add innodb_buffer_pool_instances = 4
          add innodb_file_format = barracuda
            So what's your sqltuner latest report? with new settings applied.
              tyrro
              It seems that now everything ok.
              [--] Data in InnoDB tables: 141.7M (Tables: 407)
              [--] Up for: 1d 18h 6m 27s (784K q [5.177 qps], 13K conn, TX: 4G, RX: 178M)
              [--] Reads / Writes: 73% / 27%
              [--] Max MySQL memory : 1.5G
              [--] Total buffers: 646.0M global + 17.3M per thread (50 max threads)
              [--] P_S Max memory usage: 72B
              [OK] Maximum reached memory usage: 905.3M (45.60% of installed RAM)
              [OK] Maximum possible memory usage: 1.5G (76.08% of installed RAM)
              [OK] Overall possible memory usage with other process is compatible with memory available
              [OK] Slow queries: 0% (0/784K)
              [OK] Highest usage of available connections: 30% (15/50)
              [!!] Aborted connections: 18.86% (2544/13489)
              [!!] Query cache may be disabled by default due to mutex contention.
              [OK] Query cache efficiency: 32.0% (86K cached / 270K selects)
              [OK] Query cache prunes per day: 0
              [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 10K sorts)
              [OK] Temporary tables created on disk: 3% (17K on disk / 483K total)
              [OK] Thread cache hit rate: 99% (40 created / 13K connections)
              [OK] Table cache hit rate: 96% (170K hits / 176K requests)
              [OK] table_definition_cache(2097152) is upper than number of tables(602)
              [OK] Open file limit used: 0% (4/1K)
              [--] Memory used by P_S: 72B
              [--] Using default value is good enough for your version (10.5.12-MariaDB-1:10.5.12+mariafocal)
              [!!] Key buffer used: 18.3% (6M used / 33M cache)
              [OK] Key buffer size / total MyISAM indexes: 32.0M/1.3M
              [OK] InnoDB buffer pool / data size: 256.0M/141.7M
              [OK] Ratio InnoDB log file size / InnoDB Buffer pool size: 64.0M * 1/256.0M should be equal to 25%[--] Number of InnoDB Buffer Pool Chunk : 2 for 1 Buffer Pool Instance(s)
              [OK] InnoDB Read buffer efficiency: 99.93% (9661860 hits/ 9668846 total)
              [!!] InnoDB Write Log efficiency: 823.04% (56551 hits/ 6871 total)
              [OK] InnoDB log waits: 0.00% (0 waits / 63422 writes)
              [!!] Aria pagecache hit rate: 82.4% (99K cached / 17K reads)
              Reduce or eliminate unclosed connections and network issues
              query_cache_size (=0)
              query_cache_type (=0)
