I can't create a wordpress site. I ran this command: wo site create bio.adoreanime.com --wpfc
[32m2021-10-13 08:32:08,650 (INFO) wo : Initializing WordOps Database[0m
[36m2021-10-13 08:32:08,674 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for Nginx[0m
[36m2021-10-13 08:32:10,183 (DEBUG) wo.core.logging : [95mFinding string SCRIPT_FILENAME to file /etc/nginx/fastcgi_params[0m
[36m2021-10-13 08:32:10,184 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for PHP[0m
[36m2021-10-13 08:32:11,377 (DEBUG) wo.core.logging : [95mSetting apt_packages variable for MySQL[0m
[36m2021-10-13 08:32:11,378 (DEBUG) wo.core.logging : [95mRunning command: /usr/bin/mysqladmin ping[0m
[36m2021-10-13 08:32:11,395 (DEBUG) wo.core.logging : [95mCommand Output: mysqld is alive
Command Error: [0m
[36m2021-10-13 08:32:11,396 (DEBUG) wo.core.logging : [95mSetting packages variable for WP-CLI[0m
[36m2021-10-13 08:32:11,397 (DEBUG) wo.core.logging : [95m'Namespace' object has no attribute 'web'[0m
[32m2021-10-13 08:32:11,397 (INFO) wo : [94mRunning pre-run checks[0m
[36m2021-10-13 08:32:11,398 (DEBUG) wo.core.logging : [95mchecking NGINX configuration ...[0m
[32m2021-10-13 08:32:11,524 (INFO) wo : [92mRunning pre-update checks[0m
[32m2021-10-13 08:32:11,525 (INFO) wo : [94mSetting up NGINX configuration [0m
[36m2021-10-13 08:32:11,529 (DEBUG) wo.core.logging : [95mChecking generated nginx conf, please wait...[0m
[32m2021-10-13 08:32:11,780 (INFO) wo : [94m[[0mDone[94m][0m
[36m2021-10-13 08:32:11,781 (DEBUG) wo.core.logging : [95mCreating Symbolic link, Source:/etc/nginx/sites-available/bio.adoreanime.com, Dest:/etc/nginx/sites-enabled/bio.adoreanime.com[0m
[32m2021-10-13 08:32:11,782 (INFO) wo : [94mSetting up webroot [0m
[36m2021-10-13 08:32:11,782 (DEBUG) wo.core.logging : [95mCreating Symbolic link, Source:/var/log/nginx/bio.adoreanime.com.access.log, Dest:/var/www/bio.adoreanime.com/logs/access.log[0m
[36m2021-10-13 08:32:11,783 (DEBUG) wo.core.logging : [95mCreating Symbolic link, Source:/var/log/nginx/bio.adoreanime.com.error.log, Dest:/var/www/bio.adoreanime.com/logs/error.log[0m
[32m2021-10-13 08:32:11,783 (INFO) wo : [94m[[0mDone[94m][0m
[32m2021-10-13 08:32:11,913 (INFO) wo : [94mDownloading WordPress [0m
[36m2021-10-13 08:32:11,913 (DEBUG) wo.core.logging : [95mChanging directory to /var/www/bio.adoreanime.com/htdocs/[0m
[36m2021-10-13 08:32:11,914 (DEBUG) wo.core.logging : [95mRunning command: wp --allow-root core download[0m
[36m2021-10-13 08:32:13,905 (DEBUG) wo.core.logging : [95mCommand Output: Downloading WordPress 5.8.1 (en_US)...
Using cached file '/root/.wp-cli/cache/core/wordpress-5.8.1-en_US.tar.gz'...
Success: WordPress downloaded.
Command Error: [0m
[32m2021-10-13 08:32:13,907 (INFO) wo : [94m[[0mDone[94m][0m
[32m2021-10-13 08:32:13,907 (INFO) wo : [94mSetting up database [0m
[36m2021-10-13 08:32:13,907 (DEBUG) wo.core.logging : [95mCreating database bio_adoreanime_com_VdoZwpOe[0m
[36m2021-10-13 08:32:13,912 (DEBUG) wo.core.logging : [95m[0m
[36m2021-10-13 08:32:13,914 (DEBUG) wo.core.logging : [95mExecuting MySQL Statement : create database `bio_adoreanime_com_VdoZwpOe`[0m
[36m2021-10-13 08:32:13,915 (DEBUG) wo.core.logging : [95mCreating user bioadoreanimiqjk[0m
[36m2021-10-13 08:32:13,916 (DEBUG) wo.core.logging : [95mcreate user `bioadoreanimiqjk`@`localhost` identified by ''[0m
[36m2021-10-13 08:32:13,920 (DEBUG) wo.core.logging : [95mSetting up user privileges[0m
[36m2021-10-13 08:32:13,922 (DEBUG) wo.core.logging : [95mExecuting MySQL Statement : grant select, insert, update, delete, create, drop, references, index, alter, create temporary tables, lock tables, execute, create view, show view, create routine, alter routine, event, trigger on `bio_adoreanime_com_VdoZwpOe`.* to `bioadoreanimiqjk`@`localhost`[0m
[32m2021-10-13 08:32:13,925 (INFO) wo : [94m[[0mDone[94m][0m
[36m2021-10-13 08:32:13,925 (DEBUG) wo.core.logging : [95mChanging directory to /var/www/bio.adoreanime.com/htdocs/[0m
[36m2021-10-13 08:32:13,925 (DEBUG) wo.core.logging : [95mSetting up wp-config file[0m
[36m2021-10-13 08:32:13,926 (DEBUG) wo.core.logging : [95mGenerating wp-config for WordPress Single site[0m
[36m2021-10-13 08:32:13,926 (DEBUG) wo.core.logging : [95m/bin/bash -c "/usr/local/bin/wp --allow-root config create --dbname='bio_adoreanime_com_VdoZwpOe' --dbprefix='wp_' --dbuser='bioadoreanimiqjk' --dbhost='localhost' --dbpass= --extra-php<<PHP
define('WP_DEBUG', false);
PHP"[0m
[36m2021-10-13 08:32:14,086 (DEBUG) wo.core.logging : [95mCommand Output: Success: Generated 'wp-config.php' file.
Command Error: [0m
[32m2021-10-13 08:32:14,087 (INFO) wo : [94mConfiguring WordPress[0m
[36m2021-10-13 08:32:14,088 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set WP_CACHE_KEY_SALT 'bio.adoreanime.com:' "[0m
[36m2021-10-13 08:32:14,237 (DEBUG) wo.core.logging : [95mCommand Output: Success: Updated the constant 'WP_CACHE_KEY_SALT' in the 'wp-config.php' file with the value 'bio.adoreanime.com:'.
Command Error: [0m
[36m2021-10-13 08:32:14,238 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set WP_MEMORY_LIMIT '128M' "[0m
[36m2021-10-13 08:32:14,384 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'WP_MEMORY_LIMIT' to the 'wp-config.php' file with the value '128M'.
Command Error: [0m
[36m2021-10-13 08:32:14,385 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set WP_MAX_MEMORY_LIMIT '256M' "[0m
[36m2021-10-13 08:32:14,534 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'WP_MAX_MEMORY_LIMIT' to the 'wp-config.php' file with the value '256M'.
Command Error: [0m
[36m2021-10-13 08:32:14,535 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set CONCATENATE_SCRIPTS 'false' --raw"[0m
[36m2021-10-13 08:32:14,695 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'CONCATENATE_SCRIPTS' to the 'wp-config.php' file with the raw value 'false'.
Command Error: [0m
[36m2021-10-13 08:32:14,696 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set WP_POST_REVISIONS '10' "[0m
[36m2021-10-13 08:32:14,844 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'WP_POST_REVISIONS' to the 'wp-config.php' file with the value '10'.
Command Error: [0m
[36m2021-10-13 08:32:14,845 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set MEDIA_TRASH 'true' --raw"[0m
[36m2021-10-13 08:32:14,981 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'MEDIA_TRASH' to the 'wp-config.php' file with the raw value 'true'.
Command Error: [0m
[36m2021-10-13 08:32:14,982 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set EMPTY_TRASH_DAYS '15' "[0m
[36m2021-10-13 08:32:15,132 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'EMPTY_TRASH_DAYS' to the 'wp-config.php' file with the value '15'.
Command Error: [0m
[36m2021-10-13 08:32:15,134 (DEBUG) wo.core.logging : [95mRunning command: /bin/bash -c "/usr/local/bin/wp --allow-root config set WP_AUTO_UPDATE_CORE 'minor' "[0m
[36m2021-10-13 08:32:15,350 (DEBUG) wo.core.logging : [95mCommand Output: Success: Added the constant 'WP_AUTO_UPDATE_CORE' to the 'wp-config.php' file with the value 'minor'.
Command Error: [0m
[32m2021-10-13 08:32:15,350 (INFO) wo : [92mConfiguring WordPress[0m
[36m2021-10-13 08:32:15,351 (DEBUG) wo.core.logging : [95mMoving file from /var/www/bio.adoreanime.com/htdocs/wp-config.php to /var/www/bio.adoreanime.com[0m
[36m2021-10-13 08:32:15,352 (DEBUG) wo.core.logging : [95mSetting up WordPress tables[0m
[32m2021-10-13 08:32:15,352 (INFO) wo : [94mInstalling WordPress[0m
[36m2021-10-13 08:32:15,352 (DEBUG) wo.core.logging : [95mCreating tables for WordPress Single site[0m
[36m2021-10-13 08:32:15,353 (DEBUG) wo.core.logging : [95m/usr/local/bin/wp --allow-root core install --url='bio.adoreanime.com' --title='bio.adoreanime.com' --admin_name='ruri' --admin_password= --admin_email='none@none.com'[0m
[36m2021-10-13 08:32:15,522 (DEBUG) wo.core.logging : [95mCommand Output: ,
Command Error: Error: Your PHP installation appears to be missing the MySQL extension which is required by WordPress.
[0m
[32m2021-10-13 08:32:15,522 (INFO) wo : [91mInstalling WordPress[0m
[36m2021-10-13 08:32:15,523 (DEBUG) wo.core.logging : [95m'setup WordPress tables failed for single site'[0m
[32m2021-10-13 08:32:15,523 (INFO) wo : [94m[91mThere was a serious error encountered...[0m
[32m2021-10-13 08:32:15,523 (INFO) wo : [94m[91mCleaning up afterwards...[0m
[36m2021-10-13 08:32:15,524 (DEBUG) wo.core.logging : [95mRemoving Nginx configuration[0m
[36m2021-10-13 08:32:15,524 (DEBUG) wo.core.logging : [95mRemoving /etc/nginx/sites-enabled/bio.adoreanime.com[0m
[36m2021-10-13 08:32:15,524 (DEBUG) wo.core.logging : [95mRemoving /etc/nginx/sites-available/bio.adoreanime.com[0m
[32m2021-10-13 08:32:15,525 (INFO) wo : [94mTesting Nginx configuration [0m
[32m2021-10-13 08:32:15,697 (INFO) wo : [92mTesting Nginx configuration [0m
[32m2021-10-13 08:32:15,698 (INFO) wo : [94mReloading Nginx[0m
[32m2021-10-13 08:32:15,756 (INFO) wo : [92mReloading Nginx[0m
[36m2021-10-13 08:32:15,789 (DEBUG) wo.core.logging : [95mRunning command: /etc/letsencrypt/acme.sh --config-home '/etc/letsencrypt/config' --list --listraw[0m
[36m2021-10-13 08:32:16,094 (DEBUG) wo.core.logging : [95mCommand Output: Main_Domain|KeyLength|SAN_Domains|CA|Created|Renew
adoreanime.com|"ec-384"|www.adoreanime.com|ZeroSSL.com|Tue 24 Aug 2021 09:03:56 AM UTC|Sat 23 Oct 2021 09:03:56 AM UTC
api.adoreanime.com|"ec-384"|no|ZeroSSL.com|Tue 24 Aug 2021 04:04:15 AM UTC|Sat 23 Oct 2021 04:04:15 AM UTC
drawanime.art|"ec-384"|www.drawanime.art|ZeroSSL.com|Tue 24 Aug 2021 01:17:28 AM UTC|Sat 23 Oct 2021 01:17:28 AM UTC
img.adoreanime.com|"ec-384"|no|ZeroSSL.com|Tue 24 Aug 2021 03:52:39 AM UTC|Sat 23 Oct 2021 03:52:39 AM UTC
img.drawanime.art|"ec-384"|no|ZeroSSL.com|Tue 24 Aug 2021 01:50:04 AM UTC|Sat 23 Oct 2021 01:50:04 AM UTC
Command Error: [0m
[36m2021-10-13 08:32:16,095 (DEBUG) wo.core.logging : [95mWriting content in /var/lib/wo/cert.csv[0m
[36m2021-10-13 08:32:16,096 (DEBUG) wo.core.logging : [95mChanging permission of /var/lib/wo/cert.csv, Perm:384[0m
[36m2021-10-13 08:32:16,096 (DEBUG) wo.core.logging : [95mFinding string bio.adoreanime.com to file /var/www/22222/conf/nginx/ssl.conf[0m
[36m2021-10-13 08:32:16,097 (DEBUG) wo.core.logging : [95mRemoving /var/www/bio.adoreanime.com[0m
[36m2021-10-13 08:32:16,249 (DEBUG) wo.core.logging : [95mdropping database `bio_adoreanime_com_VdoZwpOe`[0m
[36m2021-10-13 08:32:16,252 (DEBUG) wo.core.logging : [95mExecuting MySQL Statement : drop database `bio_adoreanime_com_VdoZwpOe`[0m
[36m2021-10-13 08:32:16,255 (DEBUG) wo.core.logging : [95mdropping user `bioadoreanimiqjk`[0m
[36m2021-10-13 08:32:16,258 (DEBUG) wo.core.logging : [95mExecuting MySQL Statement : drop user `bioadoreanimiqjk`@`localhost`[0m
[36m2021-10-13 08:32:16,264 (DEBUG) wo.core.logging : [95mExecuting MySQL Statement : flush privileges[0m
[31m2021-10-13 08:32:16,288 (ERROR) wo : [91mCheck the log for details: `tail /var/log/wo/wordops.log` and please try again[0m
