Wiking Question of understanding When I update my site with --ngxblocker where does wordops put an update that only this particular site uses the blocker? I have no change in the vhost file after the update
marty There's a wildcard include for /var/www/example.com/conf/nginx/*.conf at the site level. It adds ngxblocker.conf to that path (which then includes the ngxblocker stuff).
Wiking marty Thank You wo site create site.tld --wp --ngxblocker does not work wo site update site.tld --ngxblocker works therefore my question
