Hello Guys, I'll try to be as clear as possible, because I don't know if anyone will be able to understand me.
Wordops works perfect for Wordpress
But If I install a php Script, purchased from codecayon or elsewhere.
Installing and successfully finishing.
Any changes I make on the front-end or Back-end, or add a post or ect... HAS NO EFFECT, but if I'm going to do the same thing on another cheap hosting with cpanel, I can do everything normally...
The only thing that I notice differently, is that when I install a database through cpanel, there is an option there that I check, that all permissions are activated from the php functions.
I don't know how to do this in wordops...nothing to do, I've tried everything, does anyone have any idea what I can do?
