A new Nginx package is available for WordOps based on the latest Nginx stable release (1.20.2).
Blog post available here : https://wordops.net/new-nginx-package-for-wordops/
Hi i tried to update this but has na error
wo maintenance
updating apt-cache, please wait...
updating packages, please wait...
Oops Something went wrong!!
Check the WordOps log for more details tail /var/log/wo/wordops.log
and please try again...
When i check the tail it says..
Unpacking cpio (2.12+dfsg-6ubuntu0.18.04.4) over (2.12+dfsg-6ubuntu0.18.04.1) ...
Preparing to unpack .../15-cron_3.0pl1-128.1ubuntu1.2_amd64.deb ...
Unpacking cron (3.0pl1-128.1ubuntu1.2) over (3.0pl1-128.1ubuntu1) ...
Preparing to unpack .../16-tar_1.29b-2ubuntu0.3_amd64.deb ...
Unpacking tar (1.29b-2ubuntu0.3) over (1.29b-2ubuntu0.1) ...
Errors were encountered while processing:
/tmp/apt-dpkg-install-Z9Qn7O/01-grub2-common_2.02-2ubuntu8.23_amd64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Same problem here(Debian 10)
mdl E: Sub-process /usr/bin/dpkg returned an error code (1)
If you Google this specific error there's a lot of solutions suggested, e.g.
https://itsfoss.com/dpkg-returned-an-error-code-1/
I don't think this is a WordOps problem. At least I had no problems rolling out this release across multiple servers.
Is it safe to update that Nignx package for all of Wordops version please?
Thanks so much
Hello alexlii1971,
yes it's safe to update Nginx package for all WordOps version. There are no breaking change in Nginx configuration.
Thanks for your reply.
I am reading your official post at https://wordops.net/new-nginx-package-for-wordops/
I am quite confused by the command of wo maintenance
, and checked documentation at https://docs.wordops.net/commands/maintenance/
Will all of the packages including Php, Nginx, Mysql, etc will be updated if I do wo maintenance
please?
By the way, will Nginx configration will be overwrite if I do the command line ? apt update && apt-get --option=Dpkg::options::=--force-confdef --option=Dpkg::options::=--force-unsafe-io --option=Dpkg::options::=--force-confold --assume-yes --quiet --allow-downgrades dist-upgrade
Great thanks for your further clarification.
Hello alexlii1971,
wo maintenance
will update all packages on the server. But like the other command, it will not overwrite nginx configuration during the upgrade.
