unknownwebguy Update: I created a wordpress site with wo using command:
Actually, your project may be already configured for sub-directory install but it is pointing to not existing project database.
If that is case, your project testcomp.domain.com/htdocs/index.php is already configured for sub-directory install.
Copying testcomp.domain.com/wp-config.php over testcomp.domain.com/htdocs/backend/wp-config.php may work.
If not, I guess, You have to modify your project at testcomp.domain.com/htdocs/domain.com/htdocs/backend/wp-config.php and replace your project database configuration with WordOps created database/configuration stored in testcomp.domain.com/htdocs/domain.com/wp-config.php
Lines you have to modify:
/** The name of the database for WordPress */
define( 'DB_NAME', 'wordops-database-name' );
/** MySQL database username */
define( 'DB_USER', 'wordops-database-user' );
/** MySQL database password */
define( 'DB_PASSWORD', 'wordops-database-pass' );
/** MySQL hostname */
define( 'DB_HOST', 'localhost' );
/** Database Charset to use in creating database tables. */
define( 'DB_CHARSET', 'utf8' );
/** The Database Collate type. Don't change this if in doubt. */
define( 'DB_COLLATE', '' );
