VirtuBox
Just updateed to 3.9.9.2
WordOps (wo) upgrade to 3.9.9.2 was succesfull!
Now the error si quite different:
sudo wo site update $s --le=renew
local variable 'acme_subdomain' referenced before assignment
Same error no matter if a subdomain or not.
Same behaviour if an update is issued:
Running pre-update checks [OK]
Check the log for details: tail /var/log/wo/wordops.log and please try again
2019-10-06 01:16:05,820 (DEBUG) wo : ['/usr/local/bin/wo', 'site', 'update', '$sitename']
2019-10-06 01:16:05,825 (INFO) wo : Initializing WordOps Database
2019-10-06 01:16:05,841 (DEBUG) wo : Setting apt_packages variable for Nginx
2019-10-06 01:16:06,457 (DEBUG) wo : Finding string SCRIPT_FILENAME to file /etc/nginx/fastcgi_params
2019-10-06 01:16:06,457 (DEBUG) wo : 'Namespace' object has no attribute 'web'
2019-10-06 01:16:06,458 (INFO) wo : Running pre-update checks
2019-10-06 01:16:06,458 (DEBUG) wo : checking NGINX configuration ...
2019-10-06 01:16:06,549 (INFO) wo : Running pre-update checks
2019-10-06 01:16:06,550 (DEBUG) wo : 'webroot'
2019-10-06 01:16:06,550 (INFO) wo : Check the log for details: tail /var/log/wo/wordops.log and please try again
It seems related to acme renewal.
If you need more logs and/or tests, please, let me know.
Regards,
Paris.
