Same issue here. Spun a fresh VM on Vultr. Installed WordOps. Created two wordpress sites without https (LE). Changed DNS records in domain registrar to new server IP.
Been 2 hours and am still unable to access the sites. Pinging the domain in terminal works.
Can't access WO backend (xx,xx.xx.xx:2222) doesn't work either.
My DNS records have 2 A records. One with www and one without.
The only thing I didn't do according to the docs is use the given format (myservername.yourdomain.tld) in the prerequisites section on getting started page of WO.
-- UPDATE --
Never mind. Allowing http and https on UFW got my sites working. I've a couple of questions:
- Why and how is UFW enabled? Is it a part of "stack"?
- Why are these common ports closed by default? Shouldn't WordOps take care of this during setup?
