Gatewayy Sane here but I ran the following at the suggestion of the Dev(s), wo stack purge --netdata --force wo stack install --netdata I'm not sure if that actually corrected anything or if Netdata was having some issue yesterday.
SurM4p Yea i think so too. because i tried another server and another linux, but i always faced the same problem. glad it's all good now
VirtuBox Hello mdoooooot, netdata servers can be unavailable for few minutes when they are building new binaries, try again in few minutes.
mdoooooot VirtuBox netdata servers can be unavailable for few minutes when they are building new binaries, try again in few minutes. Hi, I have been trying for several hours
mdoooooot VirtuBox root@trevor:~# wo stack status fail2ban is not installed UFW Firewall is disabled nginx : Running php7.2-fpm: Running php7.3-fpm: Running php7.4-fpm: Running mysql : Running netdata : Running root@trevor:~# wo stack remove --netdata --force root@trevor:~# wo stack purge --netdata --force root@trevor:~# wo stack status fail2ban is not installed UFW Firewall is disabled nginx : Running php7.2-fpm: Running php7.3-fpm: Running php7.4-fpm: Running mysql : Running netdata : Running
ZinkDifferent mdoooooot have this same issue. Sometimes it takes an hour or two, and then it finally proceeds.
