• General
  • [Poll] Should we remove old php versions in WordOps
Currently WordOps support php version from 7.2 to 8.2. Should we remove php 7.2 and 7.3 ?
Should we remove old php version in WordOps
This poll has ended.
VirtuBox stickied the discussion .
I've actually stopped providing PHP 7 to my clients (just saying).
I only use 8+ for all sites. Definitely prune off the oldies.
What does "remove" mean? If I have an old site running PHP 7.2 and I update WordOps does my site break?
    kingkool68 No it will not break your site currently running with PHP 7.2, but you will not be able to create new site with php 7.2 and on new server install php7.2 will not be available.
    2 months later
    Yes, keep only php7.4 and newer
    8 months later
    VirtuBox unstickied the discussion .
