• Support
  • Redirect HTTP to HTTPS with NGINX
It seems there are several custom Nginx settings by Wordops.
1# In the /etc/nginx/sites-available/myiste.com:
server {
    # Uncomment the following line for domain mapping
    # listen 80 default_server;
    server_name mysite.com *.mysite.com;
    #server_name_in_redirect off;
    access_log /var/log/nginx/lovcour.com.access.log rt_cache;
    error_log /var/log/nginx/lovcour.com.error.log;
    root /var/www/lovcour.com/htdocs;
    index index.php index.html index.htm;
    include common/wpfc-php81.conf;
    include common/wpcommon-php81.conf;
    include common/locations-wo.conf;
    include /var/www/lovcour.com/conf/nginx/*.conf;
2# But ports is defined in /var/www/mysite.com/conf/nginx/ssl.conf:
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate     /etc/letsencrypt/live/mysite.com/fullchain.pem;
ssl_certificate_key     /etc/letsencrypt/live/mysite.com/key.pem;
ssl_trusted_certificate /etc/letsencrypt/live/mysite.com/ca.pem;
ssl_stapling_verify on;
3# There is also a default file in the directory etc/nginx/sites-availabe.
I was got lost, how should I set "Redirect HTTP to HTTPS with NGINX" please? which file should I touch please?
Thanks so much.
14 days later
You don't need to configure the redirect, WordOps does it for you in /etc/nginx/conf.d/force-ssl-site.tld.conf
    a month later
    JuanMaia Great thanks, and sorry for missing your reply.
    In my case, I note there is configration file of force-ssl-lovcour.com.conf.disabled.
    Does that mean it was already disabled?
    What might be cause it to be disabled?
    What is the command line to enable it properly in Wordops please?
