Hello there
I'm in my updating day, so I'm checking all my servers.
It's really weird because I've been able to update wordops in almost every server but in this one in particular, I'm getting this error
Welcome to WordOps install/update script v3.22.0
Installing wo dependencies [OK]
Installing WordOps [KO]
Running post-install steps [OK]
wo: line 932: wo: command not found
WordOps (wo) installed successfully
As a common issue, I've followed the rule
The command wo update failed
If you have any issue when you want to update WordOps, do not hesitate to use the initial install command :
wget -qO wo wops.cc && sudo bash wo_
And the KO persist
I've followed also the "WordOps commands are not working" rule
sudo rm -f /usr/local/bin/wo && wget -qO wo wops.cc && sudo bash wo
but again, I get that KO.
Any ideas? The server is running on Ubuntu 20.04 LTS
Thanks in advance
