Hello Gatewayy,
It should work out of the box with laravel, but you may have to create a custom Nginx configuration (to replace common/php72.conf
in your vhost), with php7.2 it should look like that :
location / {
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass php72;
fastcgi_index index.php;
include fastcgi_params;
