Kyzoe when installing WordOps the text color is blue, which is hard to read, wouldn't it be better to change it to White?
VirtuBox Hello Kyzoe, I never noticed this issue with MobaXterm or on travis-ci logs. What terminal are you using ?
kingkool68 I agree. I'm using iTerm 2 with a slightly transparent background color. Here's a screenshot https://cloudup.com/c0QwWxUqYv6
VirtuBox Ah ok kingkool68, the blue color isn't the same at all in xterm. I will take a look on this, to display something easier to read.
portofacil If you use iTerm you can configure your own color scheme. It's better to solve the issue at your own taste than forcing non essential changes to code, IMHO.
