Hello community, how are you doing?
So I have a laptop with ubuntu 18.04 Lts for development and learning.
I did the installation of WordOps as the link below:
https://docs.wordops.net/getting-started/installation-guide/
All steps were performed successfully.
I was also able to create the site with the command wo site create programadorweb.tld.
But when opening on my machine the same does not run, I would like to run locally on my machine. It is possible? If not is there any other possibility?
I thank you all for your attention.
