I don't see any new config file in /etc/nginx/common
And my site still using php7.0
A little help please.
Thanks.
Thanks.
kennguyen Yeah, I'm also having issues.
I tried both ee site update example.com --php72
and wo site update example.com --php72
and neither worked.
Hoping @Michel or @jeroenops might weigh in here.
Are you using the newest version? There was a bug, with the ports, which has been solved a couple of weeks ago. It's also possible to fix this manually, by opening the upstream.conf
file and editing the PHP port from 9070
to 9072
and 9170
to 9172
for the debugging.
jeroenops Yes, I'm using the newest version that I installed yesterday. Now what should I do?
root@servidor-juliocorrea:# wo site update xxx.com.br --php72
Site xxx.com.br does not exist.
What happen??
