I had to reinstall wordops. After removing it and reinstalling, wo commands are not found, though prompt says it is installed successfully. "/usr/local/bin/wo" directory was not created during installation process. Any Idea why?
Welcome to WordOps install/update script v3.11.4
Installing wo dependencies [OK]
Installing WordOps [OK]
Running post-install steps [OK]
wo: line 755: wo: command not found
WordOps (wo) installed successfully
