While trying to install the website using the wo site create example.com --wp --php73 --letsencrypt command,
the error below continuously occurs.
Issuing SSL cert with acme.sh
Unable to install certificate
Please make sure that your site is pointed to
same server on which you are running Let's Encrypt Client
to allow it to verify the site automatically.
I have tried testing using many different domain address, and using Ping and NSlookup, I have verified that DNS is correctly configured to my server.
Could you tell me how do i fix this?
Thank you.
