portofacil
root@vps:~# tail /var/log/wo/wordops.log
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sendmail : Depends: sendmail-bin but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
2020-05-25 19:16:04,461 (INFO) wo : Oops Something went wrong!!
2020-05-25 19:16:04,462 (ERROR) wo : Check the WordOps log for more details tail /var/log/wo/wordops.log
and please try again...
