VirtuBox 2019-08-29 15:13:45,422 (DEBUG) wo : ['/usr/local/bin/wo', 'site', 'update', 'correamidia.com', '-le', '--dns=dns_do']
2019-08-29 15:13:45,434 (INFO) wo : Initializing WordOps Database
2019-08-29 15:13:45,448 (DEBUG) wo : 'Namespace' object has no attribute 'web'
2019-08-29 15:13:45,449 (DEBUG) wo : Validation : DNS mode with dns_do
2019-08-29 15:13:45,449 (INFO) wo : Issuing domain SSL cert with acme.sh
2019-08-29 15:13:45,450 (INFO) wo : Validation mode : DNS with dns_do
2019-08-29 15:13:45,450 (DEBUG) wo : Running command: /etc/letsencrypt/acme.sh --config-home '/etc/letsencrypt/config' --issue -d correamidia.com -d www.correamidia.com --dns dns_do -k "ec-384" -f
2019-08-29 15:13:46,542 (DEBUG) wo : Command Output: [Thu Aug 29 15:13:45 UTC 2019] Multi domain='DNS:correamidia.com,DNS:www.correamidia.com'
[Thu Aug 29 15:13:46 UTC 2019] Getting domain auth token for each domain
Command Error: [Thu Aug 29 15:13:46 UTC 2019] Create new order error. Le_OrderFinalize not found. {
"type": "urn:ietf:params:acme:error:rateLimited",
"detail": "Error creating new order :: too many certificates already issued for exact set of domains: correamidia.com,www.correamidia.com: see https://letsencrypt.org/docs/rate-limits/",
"status": 429
[Thu Aug 29 15:13:46 UTC 2019] Please add '--debug' or '--log' to check more details.
[Thu Aug 29 15:13:46 UTC 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh
2019-08-29 15:13:46,543 (ERROR) wo : Unable to install certificate
2019-08-29 15:13:46,543 (ERROR) wo : Please make sure that your site is pointed to
same server on which you are running Let's Encrypt Client
to allow it to verify the site automatically.
