tyrro You were blocked b/c you were using login via keys.
Actually, no, before I run 'wo secure --ssh --allowpassword', I use only password for root SSH login, and I was blocked out, if it is not expected behaviour, then it might be a bug.
tyrro allowpassword authentication is only allow to login with password, it has nothing to do with FTP.
Thanks for reply.
For example, there are two root privileges users: root, alex
If I run wo secure --allowpassword or run wo secure --ssh, does that mean both user of root and alex will need only password to login by ssh?
If yes, can I run "wo secure --allow password root" so that only allow root user account to login by ssh with password?
what I mean is that wo secure --allowpassword or run wo secure --ssh will apply rules on all root privileges users, or only apply the user that is already loged in?
It would much thanks if you like to clarify.
Great thanks
