tyrro
Thanks for reply, and sorry for miss your reply.
Two questions please:
1#
When I check wp-config.php upon define( 'WP_CACHE_KEY_SALT', 'yourdomain.com:' );
it show like this way:
define( 'WP_CACHE_KEY_SALT', '!_+[ `tI%6=>B=:p=[yKm;FGHF.?<69r!GGJHKLT:3h:e{?9;=N];thQ^@+jrD' );
I mean, there is no yourdomain.com, but it show a string of '!_+[ `tI%6=>B=:p=[yKm;FGHF.?<69r!GGJHKLT:3h:e{?9;=N];thQ^@+jrD' )
Is that right?
2#
You said:
x-srcache-fetch-status: HIT means the page was fetched from the cache.
x-srcache-store-status: BYPASS means the request doesn’t need to be stored in the cache
When I run "sudo curl -X GET -I mydomain.com", it indeed show:
What does "BYPASS means the request doesn’t need to be stored in the cache" exactly mean here? does it mean, the page is already cached, so the cache system will not store the cache page? or, does it mean there is some issue?
Thanks so much
