I am not able to create a site, because downloading wordpress fails:
wo site create site.tld --wpfc --php74
Result:
Running pre-update checks [OK]
Setting up NGINX configuration [Done]
Setting up webroot [Done]
Downloading WordPress [Fail]
There was a serious error encountered...
Cleaning up afterwards...
Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/wo/cli/plugins/site_create.py", line 375, in default
wo_wp_creds = setupwordpress(self, data, vhostonly)
File "/usr/local/lib/python3.8/dist-packages/wo/cli/plugins/site_functions.py", line 276, in setupwordpress
raise SiteError("download WordPress core failed")
wo.cli.plugins.site_functions.SiteError: 'download WordPress core failed'
During handling of the above exception, another exception occurred:
File "/usr/local/bin/wo", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.8/dist-packages/wo/cli/main.py", line 102, in main
app.run()
File "/usr/local/lib/python3.8/dist-packages/cement/core/foundation.py", line 882, in run
return_val = self.controller._dispatch()
File "/usr/local/lib/python3.8/dist-packages/cement/core/controller.py", line 471, in _dispatch
return func()
return func()
File "/usr/local/lib/python3.8/dist-packages/cement/core/controller.py", line 477, in _dispatch
return func()
File "/usr/local/lib/python3.8/dist-packages/wo/cli/plugins/site_create.py", line 392, in default
dbhost=data['wo_mysql_grant_host'])
KeyError: 'wo_mysql_grant_host'
i searched and know maybe deleted the config.yml, but i don't know how to delete it, don't know where is it. thank you
