Hello there!
Just like some of you, I'm stuck updating wordops and stacks packages. I've read this full thread and take step by step but:
I've started with "wo maintenance" and gets
mariadb-client-10.3 conflicts with mysql-client-core-5.5
mariadb-client-core-10.3 conflicts with mysql-client-5.5
Unmet dependencies. Try 'apt --fix-broken install'
I tried "wo stack migrate --mariadb"
and gets
/usr/bin/zstd: error while loading shared libraries: liblzma.so.5: cannot open shared object file: No such file or directory
mysqldump: Got errno 32 on write
So I tried the manual " aptitude install mariadb-server"
and gets
dpkg: dependency problems prevent configuration of mariadb-client-10.3:
mariadb-server-core-10.3 (1:10.3.38+maria~ubu2004) breaks mariadb-client-10.3 (<< 1:10.3.38+maria~ubu2004) and is installed.
Version of mariadb-client-10.3 to be configured is 1:10.3.25-0ubuntu0.20.04.1.
dpkg: error processing package mariadb-client-10.3 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of mariadb-backup:
mariadb-backup depends on mariadb-client-core-10.3 (= 1:10.3.38+maria~ubu2004); however:
Version of mariadb-client-core-10.3 on system is 1:10.3.25-0ubuntu0.20.04.1.
dpkg: error processing package mariadb-backup (--configure):
dpkg: dependency problems prevent configuration of mariadb-server-10.3:
mariadb-server-10.3 depends on mariadb-client-10.3 (>= 1:10.3.38+maria~ubu2004); however:
Version of mariadb-client-10.3 on system is 1:10.3.25-0ubuntu0.20.04.1.
dpkg: error processing package mariadb-server-10.3 (--configure):
dpkg: dependency problems prevent configuration of mariadb-server:
mariadb-server depends on mariadb-server-10.3 (>= 1:10.3.38+maria~ubu2004); however:
Package mariadb-server-10.3 is not configured yet.
dpkg: error processing package mariadb-server (--configure):
Processing triggers for libc-bin (2.31-0ubuntu9) ...
Errors were encountered while processing:
mariadb-client-10.3
mariadb-backup
mariadb-server-10.3
mariadb-server
Current status: 3 (-1) broken, 323 (-1) upgradable.
So I've continued trying with "wo stack upgrade --mysql"
and again:
The following packages have unmet dependencies:
mariadb-backup : Depends: mariadb-client-core-10.3 (= 1:10.3.38+maria~ubu2004) but 1:10.3.25-0ubuntu0.20.04.1 is to be installed
mariadb-server-10.3 : Depends: mariadb-client-10.3 (>= 1:10.3.38+maria~ubu2004) but 1:10.3.25-0ubuntu0.20.04.1 is to be installed
mariadb-server-core-10.3 : Breaks: mariadb-client-10.3 (< 1:10.3.38+maria~ubu2004) but 1:10.3.25-0ubuntu0.20.04.1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I've checked "mysqlcheck --all-databases"
and everything is ok.
So here I am, unable to update mariadb in this "unmet dependencies" loop.
I want to create new sites in this server and I would like to make it with everything updated.
Let me know if you see the solution here.
Thanks in advance.
D.
