VirtuBox Hi, after changing vhost and nextcloud.conf like your settings, all the installation work fine for me (Nextcloud 20.0.1.1). But when I try to go to settings page, I got Internal Server Error and log like this
{"reqId":"8yqYndTzDBt29BoARHPE","level":3,"time":"2020-11-02T13:15:15+00:00","remoteAddr":"171.250.245.141","user":"stevenlam","app":"index","method":"GET","url":"/settings/user","message":{"Exception":"Doctrine\\DBAL\\Exception\\InvalidFieldNameException","Message":"An exception occurred while executing 'SELECTdataFROMoc_accountsWHEREuid= ?' with params [\"stevenlam\"]:\n\nSQLSTATE[42S22]: Column not found: 1054 Unknown column 'data' in 'field list'","Code":0,"Trace":[{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":149,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":914,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Accounts/AccountManager.php","line":141,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Settings/Personal/PersonalInfo.php","line":106,"function":"getUser","class":"OC\\Accounts\\AccountManager","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\Settings\\Settings\\Personal\\PersonalInfo","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":77,"function":"formatSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php","Line":60,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[42S22]: Column not found: 1054 Unknown column 'data' in 'field list'","Code":"42S22","Trace":[{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":906,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Accounts/AccountManager.php","line":141,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Settings/Personal/PersonalInfo.php","line":106,"function":"getUser","class":"OC\\Accounts\\AccountManager","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\Settings\\Settings\\Personal\\PersonalInfo","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":77,"function":"formatSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":129,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S22]: Column not found: 1054 Unknown column 'data' in 'field list'","Code":"42S22","Trace":[{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","line":127,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":906,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Accounts/AccountManager.php","line":141,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Settings/Personal/PersonalInfo.php","line":106,"function":"getUser","class":"OC\\Accounts\\AccountManager","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\Settings\\Settings\\Personal\\PersonalInfo","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":77,"function":"formatSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/apps/settings/lib/Controller/PersonalSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\PersonalSettingsController","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/cloud.phatdev.net/htdocs/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/cloud.phatdev.net/htdocs/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/cloud.phatdev.net/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":127}},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.1 Safari/605.1.15","version":"20.0.1.1"}
