Greetings!
I'm trying to update MariaDB to version 10.5, however, when I use the wo stack migrate --mariadb command, I get the errors below.
I have little experience with servers, so could someone help me solve this problem?
`Incorrect parameters
Usage :
zstd [args] [FILE(s)] [-o file]
FILE : a filename
with no FILE, or when FILE is - , read standard input
Arguments :
-# : # compression level (1-19, default:3)
-d : decompression
-D file: use file as Dictionary
-o file: result stored into file (only if 1 input file)
-f : overwrite output without prompting
--rm : remove source file(s) after successful de/compression
-k : preserve source file(s) (default)
-h/-H : display help/long help and exit
mysqldump: Got errno 32 on write`
Thank you!
Sandy
