Issuing SSL cert with acme.sh [KO]
Your domain is properly configured but acme.sh was unable to issue certificate.
You can find more informations in /var/log/wo/wordops.log
Logs -
[36m2020-11-14 13:09:45,835 (DEBUG) wo.core.logging : [95mCommand Output: [Sat Nov 14 13:09:36 UTC 2020] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sat Nov 14 13:09:36 UTC 2020] Multi domain='DNS:softkeymart.com,DNS:www.softkeymart.com'
[Sat Nov 14 13:09:36 UTC 2020] Getting domain auth token for each domain
[Sat Nov 14 13:09:39 UTC 2020] Getting webroot for domain='softkeymart.com'
[Sat Nov 14 13:09:40 UTC 2020] Getting webroot for domain='www.softkeymart.com'
[Sat Nov 14 13:09:40 UTC 2020] Verifying: softkeymart.com
Command Error: [Sat Nov 14 13:09:43 UTC 2020] softkeymart.com:Verify error:Invalid response from https://softkeymart.com/.well-known/acme-challenge/HY8rtQ82iKeacApM0_9lqTj24mlS2HzDUDb79YawiTY [68.183.92.37]:
[Sat Nov 14 13:09:43 UTC 2020] Please add '--debug' or '--log' to check more details.
[Sat Nov 14 13:09:43 UTC 2020] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[0m
[32m2020-11-14 13:09:45,836 (INFO) wo : [91mIssuing SSL cert with acme.sh[0m
[31m2020-11-14 13:09:45,836 (ERROR) wo : [91mYour domain is properly configured but acme.sh was unable to issue certificate.
You can find more informations in /var/log/wo/wordops.log[0m[36m2020-11-14 13:09:45,835 (DEBUG) wo.core.logging : [95mCommand Output: [Sat Nov 14 13:09:36 UTC 2020] Using CA: https://acme-v02.api.letsencrypt.org/directory
[0m
