I ran the wo update command with odd results:
Downloading update script [Done]
updating WordOps, please wait...
Welcome to WordOps install/update script v3.13.2
Installing wo dependencies [OK]
Installing WordOps [KO]
Running post-install steps [OK]
/var/lib/wo/tmp/woupdate20201125-050808: line 860: wo: command not found
WordOps (wo) upgrade to v3.13.2 was succesfull!
Changelog is available on https://github.com/WordOps/WordOps/releases/tag/v3.13.2
To upgrade WordOps web stacks, you can use the command:
wo stack upgrade
Please note the "KO" and then the message after "Running post-install steps"
Then of course, when I try to run wo stack upgrade I get the message that bash: /usr/local/bin/wo: No such file or directory
which makes sense from the message above -- even though there was a message that WordOps (wo) upgrade to v3.13.2 was succesfull!
So, what now? I am new to WordOps and this is the first time I have had to run these commands.
