nsgoyat You can edit /etc/nginx/nginx.conf file to change the value for this particular header or remove the whole line entirely.
alexlii1971 nsgoyat I am just curious, is there any potential issue if it is changed or removed? thanks
fidividi Thanks, sorted. Anyone else interested a sudo systemctl reload nginx is required after that change in order for it to take effect.
portofacil alexlii1971 is there any potential issue if it is changed or removed? No, no potential problem.
nsgoyat alexlii1971 As Portofacil mentioned, there won't be any problem after removing or changing it. However, I keep it intact on most of my servers just to "spread the word-ops" :
