nsgoyat nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/nginx.service.d
└─limits.conf
Active: failed (Result: exit-code) since Wed 2021-01-13 03:50:23 EST; 48s ago
Process: 550 ExecStart=/usr/sbin/nginx (code=exited, status=1/FAILURE)
Process: 294 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=0/SUCCESS)
Jan 13 03:50:22 srv780.kantotin.net nginx[550]: nginx: [emerg] listen() to [::]:80, backlog 511 failed (98: Address already in use)
Jan 13 03:50:22 srv780.kantotin.net nginx[550]: nginx: [emerg] listen() to 0.0.0.0:80, backlog 511 failed (98: Address already in use)
Jan 13 03:50:23 srv780.kantotin.net nginx[550]: nginx: [emerg] listen() to 0.0.0.0:80, backlog 511 failed (98: Address already in use)
Jan 13 03:50:23 srv780.kantotin.net nginx[550]: nginx: [emerg] listen() to [::]:80, backlog 511 failed (98: Address already in use)
Jan 13 03:50:23 srv780.kantotin.net nginx[550]: nginx: [emerg] still could not bind()
Jan 13 03:50:23 srv780.kantotin.net systemd[1]: nginx.service: Control process exited, code=exited status=1
Jan 13 03:50:23 srv780.kantotin.net systemd[1]: Failed to start A high performance web server and a reverse proxy server.
Jan 13 03:50:23 srv780.kantotin.net systemd[1]: nginx.service: Unit entered failed state.
Jan 13 03:50:23 srv780.kantotin.net systemd[1]: nginx.service: Failed with result 'exit-code'.
