corus9 jounin check this : https://docs.wordops.net/guides/wordpress-migration/ once done run wpcli command wp search-replace https://example.com https://new.example.com
marty This guide will do it: https://docs.wordops.net/guides/wordpress-migration/ Plugins are easier for small sites.
jounin corus9 wp search-replace https://example.com https://new.example.com im using this command.. but i cant login to wp-login.php its say Unknown username. Check again or try your email address.
jounin im doing that more than 7 hrs ago.. my Old server have a marian db 10.3 and my And New Server Have marian db 10.5 which is the latest but after import the .sql database coming from the old server to new one the wordpress new domain is blank
corus9 jounin if database is blank then run this on your old server mysqlcheck --all-databases if everything is fine then do you get success message once you import database on your new server ? also as marty said leave wp-config intact no need to overwrite it
marty Would have been useful to mention that..! The database is blank or the website is blank? Did you copy the old wp-config.php into htdocs? If so, remove it (WordOps has a wp-config in the folder above).
jounin at first i remove the wp-config.php then its say create manually then i go to wordops.net/wp-admin/ to installation set up and fill out form my old wp-config then i type wp db clean --yes --allow-root wp db import wordops.sql --allow-root then success at first i go to the website but and it looks broken fresh wordpress then i login to wp-login.php and i Flush Cache and it works yay..
corus9 jounin that doesnt have to do anything with wp search-replace are you sure restore was successful ? if yes then install phpmyadmin and rest password from user table
Torwald45 You probably didn't change the prefix in wp-config.php. It must be the same as in the imported database. In Wordops, is wp_. in the imported database it may be different. It won't work without this change.
