Hi guys. I discovered Wordops after trying to install easy engine on my lightsail Ubuntu server, multiple times, without any success. Wordops came in clutch and I got my sites up and running in less than a day.
However, some issues have arisen that I kindly need help/clarification on. On one lightstail instance, I have 4 sites running (all installed with WordOps), but the issue is that the lightsail instance keeps going down / timing out, and I have to stop and start it almost every hour. When the server stops responding, I check the SSH via terminal and its blank (kind of frozen), and nothing comes up on it until I stop and start again. The specs of the lightsail instance is:
- 1GBRAM
- 1VCPU
- 40GBSSD
...is the server too small to hold the four sites (each not exceeding 1GB in size, including database)?
I'm m not so experienced with code, so I don't know how else to troubleshoot this problem.
I would appreciate your kind assistance.
Thank you,
Ruby.
