Just add a certificate wo site update example.com --letsencrypt
the rest is done.
Use HTTP/2
- Edited
marty This is for SSL. I have already.
As I said, the rest is done. Web browsers require 'SSL' for http/2, so if you've set up the certificate, then you already have http/2. Check it using your web browser dev tools.
marty Hello Marty, thank you for your response. I have an SSL certificate, but in page speed insights, I have a warning.
What does it say when you click the down arrow (on the right hand side) for more information?
That's odd - all my sites just worked out of the box.
Have you made any changes to your sites config? What's in /var/www/yoursite.com/conf/nginx/ssl.conf
(it should say listen 443 ssl http2;
etc, and there should be an include for this folder in your main site config)?
- Edited
For the SSL certificate, I use cerbot because --letsencrypt --force doesn't work for me.
I have Cloudflare DNS only.
On another website for my friend working flawless,
What can I do? I have a backup for WordPress. Delete the website and start from the beginning?
And if SSL doesn't work again?
Now can I add HTTP/2 and how?
Which is the best solution?
Finally, just add listen 443 ssl http2; Done!
Is your wordpress home address configured with https?
wp option get home
portofacil Yes
