lpienia aaronstuder I hace two type instances. 1) Woocommece site with les than 2000 daily visitors. Also sharing the server with Mautic 2) WordPress corporate sites no more than 3/4 per instance. What are the Best prsctices? And instance sizes and best setup? Regards
lpienia I hace two type instances. 1) Woocommece site with les than 2000 daily visitors. Also sharing the server with Mautic 2) WordPress corporate sites no more than 3/4 per instance. What are the Best prsctices? And instance sizes and best setup? Regards
VirtuBox lpienia Hello, it's pretty hard to tell you what would be the best size for your instances. Usually, 2 vCPU & 4GB RAM is a good choice to host several website on a server with WordOps, but it highly depend on the traffic and on site features.
lpienia VirtuBox There is not too much traffic. No more than 1000 users a day. I just have a problem, sudenly the CPU consumes 100%, everything is freezing. No traffic from the outside is comming. What I research is that php-fpm processes consumes all teh CPU don“t know why! andy guidlines? Regards,
mdoooooot lpienia Where I should disable this? and change the parameters? Thanks Can you please link me to the guide?
VirtuBox mdoooooot Disable brotli sudo sed -i 's/brotli on;/brotli off;/' /etc/nginx/nginx.conf sudo sed -i 's/brotli_static on;/brotli_static off;/' /etc/nginx/nginx.conf sudo nginx -t && sudo service nginx reload
