using the commands:
wo maintenance
or apt-get update && apt-get dist-upgrade -y
I have the following error:
Building dependency tree ...
Reading state information ...
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
mariadb-backup: Depends: mariadb-client-core-10.3 (= 1: 10.3.29 + maria ~ focal) but 1: 10.3.29-0ubuntu0.20.04.1 is installed
mariadb-server-10.3: Depends: mariadb-client-10.3 (> = 1: 10.3.29 + maria ~ focal) but 1: 10.3.29-0ubuntu0.20.04.1 is installed
mariadb-server-core-10.3: Breaks: mariadb-client-10.3 (<1: 10.3.29 + maria ~ focal) but 1: 10.3.29-0ubuntu0.20.04.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
the apt --fix-broken install command is not the solution.
these dependencies of mariadb exist and make it impossible to use the commands:
wo maintenance
wo stack upgrade --mysql
wo stack migrate --mariadb --force
Has anyone had this problem and managed to revert?
